Carling rear wash pipe switch advice needed.
Frax
Hi all I have a rear wiper wash switch from Carling and wondered if anyone could give me some advice on the wiring.
It says that I should have a black wire with a light green trace,
I have a black but no trace.
Green I have and I take it that this is the one that is split to two points.
Got the others.
Regards
Frax :unsure:
black/light green trace is for the rear washer pump from the switch. there's a darker plain green wire that comes from header joint C285-3 to the switch supplies 12v feed in, plain black is a earth wire
have you got a copy of the wiring diagram ?
if not see below attachment.
hth.
