VDO Oil pressure gauge wiring
Frax
Hi
Have another little problem - I have fitted a VDO oil pressure gauge and wired it up as follows.
+ = 12v ignition feed
G = Signal from oil pressure sender.
The other terminal I grounded.
When I turn on the ignition with engine not running the gauge goes full scale.
Have I made another mess of things ????????????
Regards
Frax
does the pressure sender look like these VDO units or is it the LR cadmium plated variant,
VDO gauges seem very particular to work with their own VDOsenders, my oil temp gauge wouldn't work with the LR switch but is OK with the VDO unit,
gauge markings looking at back of gauge with illumination bulb holder at the top
+ on left to 12v
- on bottom to earth
S on right to sender
reckon one of the wires is wrong to make it show full scale, it shouldn't read until the engine is running.
