peterdon Posted November 25, 2011 Share Posted November 25, 2011 Easy question - How do I tell which is the negative side of the coil? Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2011 Share Posted November 25, 2011 it should be marked - negative & + positive. either by using the symbols or words. on the body or end cap where the terminals are moulded in. markings can be seen on this coil positive nearest & negative furthest Quote Link to comment Share on other sites More sharing options...
peterdon Posted November 25, 2011 Author Share Posted November 25, 2011 Thanks, that's what I thought. I must clean mine up and have a closer look! Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 25, 2011 Share Posted November 25, 2011 On some types the positive is a bigger screw, The positve should also be a slightly higher resistance to the centre terminal too. Quote Link to comment Share on other sites More sharing options...
