Lightweight cooling fan bolts
Steve_M
Are you removing the Kenlowe then Steve?
Mark
Yes, not really out of choice though I think I got it all a little too wet and the thermosat packed up followed by the fan a few weeks later. When I get round to it I will probably have a go a taking the fan to pieces to see if I can't fix it, in the mean time I am going to fit a military fan I have picked up as a quick fix.
Regards,
Steve
Is it a Kenlowe capillary stat ?
These are notorious for filling with mud and water an corroding internally, I ended up spaying WD40 in every month as a precaution and the day following getting water under the bonnet ;)
Changed it in the end for an electronic one
Yes, it is the standard Kenlowe unit, if/when I put an electric fan back in I will probably look at alternatives.
Steve, Have a look at fitting one of the X-eng x-therm switches rather than the kenlowe 'stat.
As you say the fan that is on there is somewhat huge (and sounds like a turbine) but that engine does run warm so don't skimp on the cooling.
Cheers
Mark
Cheers
Mark
The X-eng switches do look good and I will probably end up getting one of these. When I replace the fan (assuming I can't fix the old one) I intended to use the same size as it seems to be about right.
Regards,
Steve
