88 inch of pure pleasure Posted November 26, 2011 Share Posted November 26, 2011 Right I have a td5 discovery as the story goes the clutch has been slipping for a while but only now n then.anyhow it started to make a chattering noise a friends made similar noise (almost like a heat shield rattle) it turned out to be the flywheel to this I didn't mind as I could change it during the clutch change.but last night while driving home as I let my foot off the gas it started with a vibration and a noise asif someone had tipped a bag of spanners in something important,no lights illuminated until the engine died (just asif I'd turned the key off not sudden)and now it won't turn ova asif seized! But oil water temps were all good! Sumone said the flywheel may have collapsed but it died slow not a sudden stop.anyone heard or had anything similar thanks Paul Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted November 27, 2011 Share Posted November 27, 2011 It is possible that the flywheel has broken up and taken out the crank position sensor. if this is broken the engine will shut down. It is also possible that pieces of the flywheel are jammed up preventing the engine from turning over. Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 27, 2011 Share Posted November 27, 2011 DMF could have seperated. Les. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 27, 2011 Share Posted November 27, 2011 Take the starter out and have a look inside (mobile phone camera or suchlike). Quote Link to comment Share on other sites More sharing options...
