DeePete Posted December 6, 2011 Share Posted December 6, 2011 Hi Guys. My '94 Disco, 2.5 TDi has started making a worrying noise while gears engaged, when accelerating, in all gears (not in reverse). When clutch depressed and freewheeling it stops. It doesn't make a noise when revving hard but not in gear, or when 'cruising' with engine under minimum load. It's a screeching sort of noise which you can hear is something rotating (?). Belts are fine, alternator is fine, pulleys seem ok, no play in waterpump pulley. It's not the whine you get off gears or diff. This seems to be pointing towards a clutch release bearing. Big job I could do without. Anyone got any other ideas? Deepete Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 6, 2011 Share Posted December 6, 2011 Does it make the noise when the engine is running in neutral with your foot off the clutch, then disappear when you press the pedal? If so - likely culprit is the thrust bearing. Les. Quote Link to comment Share on other sites More sharing options...
defender dave Posted December 7, 2011 Share Posted December 7, 2011 Hi Guys. My '94 Disco, 2.5 TDi has started making a worrying noise while gears engaged, when accelerating, in all gears (not in reverse). When clutch depressed and freewheeling it stops. It doesn't make a noise when revving hard but not in gear, or when 'cruising' with engine under minimum load. It's a screeching sort of noise which you can hear is something rotating (?). Belts are fine, alternator is fine, pulleys seem ok, no play in waterpump pulley. It's not the whine you get off gears or diff. This seems to be pointing towards a clutch release bearing. Big job I could do without. Anyone got any other ideas? Deepete that sounds like a UJ going they make a screching sound when they are on there way out Quote Link to comment Share on other sites More sharing options...
