R380 gearbox problem
Depends when it happens ? Is it when the gearbox is cold eg the first couple of changes after start up ?
I replaced my R380 and LT230 about a year ago with Ashcroft transmissions recon unit , I thought they would of been able to cure the
2nd gear cold box crunch but NO it still happen every morning .
I don't think it will ever be cured it must be a characteristic of the r380 box I have heard that Difflock oil helps this but it's quite expensive and I haven't tried it yet
Anyone confirm if it stops it totally or helps ???
Hope this helps
Chris
