s3ndy Posted January 19, 2012 Share Posted January 19, 2012 Okay so I still have not fitted my kenlowe fan yet but I am already getting more parts for my next mod A heated front windscreen hehe Got the wiring loom out of a late 300tdi with heated screen. Just got the screen out today but will get someone to fit this who knows what they are doing. Got the wiring loom out but I can't find the timer switch!! so on my loom I have: Two connectors which go to the windscreen two 30amp fuses (near the connectors to the screen) one 70 or 60 amp large fuse which goes into the fuse box under the bonnet and that is pretty much it apart from the wires which go to ground and some green wires which would go to the heated screen switch. anyone have a wiring diagram for this mod? I will try and get some pics of the loom this weekend. thanks Andy Quote Link to comment Share on other sites More sharing options...
s3ndy Posted January 20, 2012 Author Share Posted January 20, 2012 think I may have one or two realy switches too but can't remember as I was getting the ZZZzzzzssssss Quote Link to comment Share on other sites More sharing options...
teabag Posted January 20, 2012 Share Posted January 20, 2012 On a 300 series the timing is controlled by the multi function unit MFU. Quote Link to comment Share on other sites More sharing options...
s3ndy Posted January 20, 2012 Author Share Posted January 20, 2012 Would my disco have one of these units as mine was standard apart from the twin sunroofs. Would this mean plugging my car into a computer and turning the heated screen mfu on? then it's a case of finding where to put the wires could I not find or make a timer? just trying to find the easiest way to do this. s Unless there is anyone near Manchester who fancies the challange for 20 beers Quote Link to comment Share on other sites More sharing options...
teabag Posted January 20, 2012 Share Posted January 20, 2012 If you already have the two sockets at the lower corners of the windscreen means all the wiring is there, then all you will need is fuse, switch and relay for the empty relay socket somewhere up behind the glove box, the mfu doesn't need programming as the timing function is already there. If no existing wiring then your new wiring would be similar to any other piece of electrical kit, ie. fused 12v supply, non latching switch and a relay with a timer function and obtained from such companies as http://www.vehicle-w...me/homepage.php Quote Link to comment Share on other sites More sharing options...
s3ndy Posted January 21, 2012 Author Share Posted January 21, 2012 how long does the front heated windscreen stay on for? I don't want to get a timer switch that keeps it on too long and damages the elements. Quote Link to comment Share on other sites More sharing options...
teabag Posted January 21, 2012 Share Posted January 21, 2012 Same as the rear, appox 7 or 8 mins which is ok to clear frost. With snow you need longer so just press the button again after the first time-out for the extra time. Quote Link to comment Share on other sites More sharing options...
s3ndy Posted January 21, 2012 Author Share Posted January 21, 2012 If I get the timer whats used on the rear window would that be okay? I can get one from the scrap yard for 10p that way Quote Link to comment Share on other sites More sharing options...
teabag Posted January 21, 2012 Share Posted January 21, 2012 The D1s MFU looks after the timing function for the HRW. RRCs had a timer relay for the rear screan IIRC but I forget where now. Quote Link to comment Share on other sites More sharing options...
