kevrobbins Posted January 22, 2012 Share Posted January 22, 2012 Hi all, as it says, battery goes flat if it is not drive weekly....YYYYYYYYYYYYYY.. some thing must be draining it. new battery fitted so it's not tha & the alternator is good I did notice to day when looking for clues in the fuse box under the bonnett that the dreaded ACE relay was clicking about every 30 seconds.So I tooked out swaped it with the horn one but still kept clicking,drowned it in wd40 & it has stopped SSSSSOOOOOOOO HELP Please....Kev Quote Link to comment Share on other sites More sharing options...
kevrobbins Posted January 23, 2012 Author Share Posted January 23, 2012 any one ???????????? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted January 24, 2012 Share Posted January 24, 2012 Take out fuse F15 from engine bay, if it stops clicking, put it back and unplug the ACE ECU(behind glovebox) ... if then stops it means the ACE ECU gives a false command.... a good start would be to plug in a tester and scan the ACE. ... if the relay will click even with the fuse out we'll speak again. Quote Link to comment Share on other sites More sharing options...
