stuck Posted January 28, 2012 Share Posted January 28, 2012 Gent's, My 110 has the above winch, I'm doing away with the remote & switching it from the cab. I've figured out the solenoid wiring for in & out but can't get the warning LED's on the winch to illuminate. (I like LED's ) I've looked on Super Winch's web site & Google for a wiring diagram but can't find one for the 9.5 (the wiring appears to differ from the 9.0, white seems to be +12v, red = in & black = out. When I say "seems to be" the winch works) Any ideas? Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2012 Share Posted January 28, 2012 might help http://www.bigjimny....=1397&Itemid=75 as your just fitting a rocker switch instead of the remote, there shouldn't be much difference in the wiring Quote Link to comment Share on other sites More sharing options...
stuck Posted January 28, 2012 Author Share Posted January 28, 2012 Thanks Ralph, Doesn't help as it only about single / twin battery setups. Quote Link to comment Share on other sites More sharing options...
zim Posted January 31, 2012 Share Posted January 31, 2012 Mick, not a clue what the wiring looks like on your winch. But remember that an led will only work in one direction. Maybe you have + and - the wrong way round. G p.s how's the engine running? Quote Link to comment Share on other sites More sharing options...
stuck Posted January 31, 2012 Author Share Posted January 31, 2012 Hi G, Engine is better but not 100%, mot on Friday. If it passes could I have a drive over? Quote Link to comment Share on other sites More sharing options...
zim Posted January 31, 2012 Share Posted January 31, 2012 sure. I'm in aberdeen till Thurs night. Could check over your led wiring If you aren't sorted by then. Quote Link to comment Share on other sites More sharing options...
stuck Posted January 31, 2012 Author Share Posted January 31, 2012 Cheers G, LED's are the least of my worries, would be great to get it running spot on though. Quote Link to comment Share on other sites More sharing options...
