PieEater3142 Posted January 30, 2012 Share Posted January 30, 2012 Hey Chaps, I want to get the correct wheel arches for my Defender 110, I am trying to avoid getting fixed ones and my current 90 has nice flexible wheel arch spats/ eyebrows (I have no idea what they're called at this point). Basically does anyone have the part number for wheel arches that are flexible like rrc3043, rrc3044 and rrc3045 (I assume these are rigid). Thanks in advance, James Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2012 Share Posted January 30, 2012 they are all flexible, 90/110 never had fixed flares, new ones will be much stiffer than your current items but will soften with age. REAR http://www.numcat.ru/landrover/p/31/52740/ FRONT http://www.numcat.ru/landrover/p/31/52676/ Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted January 31, 2012 Author Share Posted January 31, 2012 Thanks western, just I've seen some with hard plastic ones and assumed they were the ones given by the codes. Do you need the liners for the front? Quote Link to comment Share on other sites More sharing options...
western Posted January 31, 2012 Share Posted January 31, 2012 the liners [item 19 in the link for front arches] are IIRC for later vehicles, my '89 110 has galvanised front inner arches with no plastic liner. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted February 2, 2012 Author Share Posted February 2, 2012 I have galvanised front inner arches. This is good news. Thanks western. As always you are the encyclopedia Defender Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2012 Share Posted February 2, 2012 glad the info was helpful. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted March 8, 2012 Author Share Posted March 8, 2012 Is there a difference between td5 and 200/300tdi wheel arches? Quote Link to comment Share on other sites More sharing options...
western Posted March 8, 2012 Share Posted March 8, 2012 inner arches on later vehicles are plastic I believe, but fixings might be the same. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted March 9, 2012 Author Share Posted March 9, 2012 sorry, meant the actual eyebrows. http://www.britishparts.co.uk/.sc/ms/dd/Defender--Body%20Fittings/2404/WHEEL%20ARCH%20EYEBROW Wondering if a td5 set will go on a 200tdi without issue? Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2012 Share Posted March 9, 2012 AFAIK the eyebrows are all the same within each mode; range ie 90 & 110. 90 or 110 rears only fit those models but 90 & 110 fronts fit either.don't forget they are handed left & right too. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted March 19, 2012 Author Share Posted March 19, 2012 sorry, just to clarify - the rears only fit one model but the fronts fit both? i.e. 90 rear on 90 only etc? Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2012 Share Posted March 19, 2012 sorry, just to clarify - the rears only fit one model but the fronts fit both? i.e. 90 rear on 90 only etc? Yes, the rear wing side panel is different between 90 & 110. Quote Link to comment Share on other sites More sharing options...
