joe sharpe Posted March 8, 2012 Share Posted March 8, 2012 does anyone know if i can buy a 300tdi rear axle casing and swap the guts over from my 200tdi axle or are they different cheers in advance joe. Quote Link to comment Share on other sites More sharing options...
joe sharpe Posted March 10, 2012 Author Share Posted March 10, 2012 does anyone know if i can buy a 300tdi rear axle casing and swap the guts over from my 200tdi axle or are they different cheers in advance joe. i think i might be miss leading what i need to know is can i put a 300tdi rear axle onto my 200tdi and what work will be involved as i have a snapped bolt in rear brake disk which i cant remove cheers joe Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 10, 2012 Share Posted March 10, 2012 I'm fairly sure thet they are the same but an easy check is the axle model number is stamped on the casing just below the air vent, if they are the same, go for it. Quote Link to comment Share on other sites More sharing options...
Phillis Posted March 16, 2012 Share Posted March 16, 2012 rear axles are interchangable, its just the fronts that have wide and narrow hockey sticks Quote Link to comment Share on other sites More sharing options...
andyb Posted March 19, 2012 Share Posted March 19, 2012 Some 300Tdi rear diffs have a 3 bolt drive flange. You can swap part to make it compatible with your 4 bolt prop..........just so a search on this forum, it's all here somewhere Quote Link to comment Share on other sites More sharing options...
