stuck Posted March 27, 2012 Share Posted March 27, 2012 Gent's, Does the standard auto fitted to a RRC have a central diff lock of any description? Transfer boxes only seem to have high / low ratio selector? I'm thinking of building a new CCV truck & would like to go auto but as you can tell I know sod all about them. Ta, Mick. Quote Link to comment Share on other sites More sharing options...
duncmc Posted March 28, 2012 Share Posted March 28, 2012 The auto box doesn't, but the transfer box does. Either a normal LT230 type, or a limited slip in the Borg Warner depending upon age/year of the donor. Quote Link to comment Share on other sites More sharing options...
zim Posted March 28, 2012 Share Posted March 28, 2012 Mick, The box only has one drive shaft coming out of it, 4 forward gear and 1 reverse. The transfer box then selects either High or Low. If you get a borg warner then it's got the viscous centre diff lock, if you go for Lt230 then you can select diff lock or not. G Quote Link to comment Share on other sites More sharing options...
stuck Posted April 11, 2012 Author Share Posted April 11, 2012 Cheers chaps, I've picked up a Borg Warner, could anyone tell me what fluid it should have in please? Normal ATF? Quote Link to comment Share on other sites More sharing options...
duncmc Posted April 11, 2012 Share Posted April 11, 2012 Yes, the usual ATF Detron 2D. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted April 13, 2012 Share Posted April 13, 2012 Mick I'd strongly recommend a sump guard arrangement to protect the casing of the BW xfer box, as they don't take kindly to being hit by rocks! I used a piece of chequer plate, and while it now conforms to the shape of the xfer box rather than being straight, the casing has not suffered any damage. Mike Quote Link to comment Share on other sites More sharing options...
