SPendrey Posted July 17, 2012 Author Share Posted July 17, 2012 Well, I used a 1325 length Goodyear belt (supplied as an after-market replacement by Paddocks) and it fits perfectly! I also bought a genuine LR one, but didn't try fitting it as it was 1322 in length. One day I'll do the honourable thing and check that belt too. Quote Link to comment Share on other sites More sharing options...
Niamh Posted July 17, 2012 Share Posted July 17, 2012 I can't see 3mm being the difference between fitting and not... Niamh Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 18, 2012 Share Posted July 18, 2012 It is quite normal (but idiotic) to have to take the idler off to replace the belt. BTDT many times now. I normally change the idler pulley bearing while I'm at it. Most of them are a common-or-garden 6203. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted July 18, 2012 Author Share Posted July 18, 2012 I was told some belts measure the inside length, others the outside.. so that 3mm could in theory be more like 7 or 8? Quote Link to comment Share on other sites More sharing options...
