carlosbeldia Posted June 11, 2012 Share Posted June 11, 2012 I'm trying to use the rear defrost button button to start / stop the air conditioner compressor in my TD5, which is directly connected due to a damaged sensor. How can I do this? where have to cut? only the positive wire that goes to the compressor? there are 3 wires going to the defrost button, does I have to use the three of them? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 11, 2012 Share Posted June 11, 2012 The rear defrost (or rear heated screen) button probably won't do what you want it to, as it's a momentary switch. In other words it doesn't turn on or off a supply when you press it, it only does it while the button is pressed down. No latching. In order to use it to control your A/C compressor, you'd need to use a latching relay to convert the momentary operation of the switch into a permanent on/off function at the compressor. Could you not replace the damaged A/C sensor? Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted June 11, 2012 Author Share Posted June 11, 2012 It's really expensive, due to I have to bring it from UK (parcel is around GBP 50 for this small sensor, which costs around 45). I don't know a thing of electricity, I just want to be able to control the compressor function from the interior. The defrost button is temporary? If I push it, it keeps on until I push it for off, at least the indicator in the instrument panel shows that way. I don't need the defrost button because I don't have glass in the back, just an acrylic (I have broken the original glass 3 times in 2 years)... Quote Link to comment Share on other sites More sharing options...
