disco_al Posted June 22, 2012 Share Posted June 22, 2012 Now, on my blue disco that's having a "refurb", the heater has always posed me a puzzler. Basically when i got it, some kind "technician" had cut the supply wire to the heater relay, and fed a live feed from the fusebox so that the blower works. The air recirculation button has never done anything, neither has the air con button. So far i have replaced with known working units (from my old disco) Heater motor (old one worked ok, but thought i'd change it anyway - just in case) Wiring from motor to control panel Air recir and air con switches Fuse box and MFU However, upon powering up the ignition (with the dash out) nothing works, not even the blower control. Any ideas are welcomed, i haven't had time to check with multimeter yet due to it being rather wet outside, and not having any cover to work under although as stated, i know the replacements work Quote Link to comment Share on other sites More sharing options...
SmasherWebbs Posted June 22, 2012 Share Posted June 22, 2012 Your going to have to either get wet or wait and use the multi meter. You will probably find its a bad connection somewhere or your not getting a earth. Quote Link to comment Share on other sites More sharing options...
disco_al Posted August 29, 2012 Author Share Posted August 29, 2012 turned out to be the ignition load relay after all the investigation.....swappped for a known good one, ad everything's peachy Quote Link to comment Share on other sites More sharing options...
