Harrod Posted July 18, 2012 Share Posted July 18, 2012 Morning Just a quick sanity check before I start, will this work?! Basically, two lights per relay, relays triggered from a carling on-on-off switch. Am I right in thinking the carling has two completely seperate circuits, i.e. circuit one is on, two is off, two is on, one is off? Many thanks! Quote Link to comment Share on other sites More sharing options...
Dave W Posted July 18, 2012 Share Posted July 18, 2012 No, on the Carling Off-On-On switches they are independent circuits but are configures as off - circuit 1 on - circuit 1 and 2 on I use a similar setup to that for my spotlights with a relay connected to each circuit. I can then have the spotlights off, the centre pair on or all four on. I can't have the outer pair on on their own. Because it wasn't complicated enough I used a second off-on-on switch in front of the spotlight switch to control if the spots were always off, on with main beam only or always on, I had to use a couple of diodes to stop the always on position feeding power back into the high beam circuit - which I think is what you are trying to do ? Quote Link to comment Share on other sites More sharing options...
Harrod Posted July 18, 2012 Author Share Posted July 18, 2012 Thought that might be the case! lets start thinking this through again! thanks Quote Link to comment Share on other sites More sharing options...
Harrod Posted July 18, 2012 Author Share Posted July 18, 2012 so youve got something more like this? Quote Link to comment Share on other sites More sharing options...
