AdeParko Posted July 24, 2012 Share Posted July 24, 2012 Jumped in the Disco this morning and the speedo needle started to jump about, and was erratic for a minute, and then just completely died Went out again the car, but there is still no speedo, just sitting at zero Rev counter is working perfectly normal Is it looking like the speed sender has broken? Its a 2.5 TD 1996 300tdi if that helps Thanks Ade Quote Link to comment Share on other sites More sharing options...
dooroy Posted July 24, 2012 Share Posted July 24, 2012 http://forums.lr4x4....6&hl=transducer. Have a look here ; probably the transducer has given up ; square ended cable that goes into gearbox drive could be worn/broken ; also check for broken/disconnected wires . Quote Link to comment Share on other sites More sharing options...
Niamh Posted September 16, 2012 Share Posted September 16, 2012 Just had a bit of this, but it came back nice and steady about 10 seconds after dying and has been fine since. 300TDi Auto FWIW. Niamh Quote Link to comment Share on other sites More sharing options...
