fozsug Posted August 28, 2012 Share Posted August 28, 2012 Can the ERR2081 temp sender that is used by the EDC controled enginges be used to send temp readings to a temp gauge. ( ERR2081 is the one located in the top of the head.) thanks Tony Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted September 5, 2012 Share Posted September 5, 2012 Well yes, it is a sensor, but whether you would get a gauge to match it correctly is another matter ... Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 5, 2012 Share Posted September 5, 2012 I was looking at this a while ago and found the datasheet for it and everything, was going to make a digital gauge - but I stopped caring. I can dig up the datasheet etc if you want? Quote Link to comment Share on other sites More sharing options...
fozsug Posted September 5, 2012 Author Share Posted September 5, 2012 I was looking at this a while ago and found the datasheet for it and everything, was going to make a digital gauge - but I stopped caring. I can dig up the datasheet etc if you want? Yes please that would be great Thanks Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 5, 2012 Share Posted September 5, 2012 Let's see... The datasheet: 194346_106193.pdf IIRC it's the one ending in 039 you need. I also had a wiring diagram somewhere of how to read it with the analog port on an IC, but I can't find it right now. Quote Link to comment Share on other sites More sharing options...
fozsug Posted September 6, 2012 Author Share Posted September 6, 2012 Thanks thats great, will let you know how i get on. Quote Link to comment Share on other sites More sharing options...
