sussex-landy Posted September 10, 2012 Share Posted September 10, 2012 Does anyone know the size of the mounting bolt for the rover 3500 V8, I have an engine stand but cant find the size of the bolt I need which will need to be 85-100mm long to mount the engine to the stand. I have some pretty close but as they start to go in you get that over tight feeling which I dont want to push and cut a new thread. thanks robert Quote Link to comment Share on other sites More sharing options...
zim Posted September 10, 2012 Share Posted September 10, 2012 Some old rocker bolts 3/8 UNC Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 12, 2012 Share Posted September 12, 2012 Yup, 3/8" UNC, I found I needed some longer ones than I had 'in stock' from other V8s, and went to local bolt supplier, they had 6 on the shelf I think I got 100mm ones as well, I assume this is a machinemart type stand? Quote Link to comment Share on other sites More sharing options...
