Help: 200TDI Alternator Pulley
ajh
Somehow I managed to misplace or worse; send to the recycler... the pulley for a 200TDI I was working on last year... now comes time to get things running again and it is nowhere to be found. Would anyone possibly have one? I'm having trouble locating one without one to send for comparison and it would be cheaper to get a new one machined than it would be to buy one from Land Rover.
if you can't get a used item, the part number is item 8 in http://www.numcat.ru/landrover/p/31/53135/ for the standard defender 200tdi 65amp alternator, it will fit a marrelli 100amp too, [got it in my 110]
http://www.lrseries.com/shop/product/listing/10956/RTC5686-ALTERNATOR-PULLEY.html
http://www.brit-car.co.uk/product.php?xProd=91279
http://www.lrdirect.com/RTC5686-Alternator-Pulley-A127/
I didn't have any luck finding a 100A when I was looking; despite many people suggesting part numbers. I ended up having to rig a new tensioner and using a 300TDI alternator that couldn't be clocked to fit but I'd love to get the right one.
Does anyone know what the maximum spin rate is on the alternators fitted to TDI? Is there any leeway to go to a slightly smaller pulley (if I'm going to machine one) to get higher amperage at lower engine RPM?
