StevenK Posted January 3, 2013 Share Posted January 3, 2013 Hi all I'm new to the forum and more importantly the new owner of a 90 td5. I'm setting to a number of small tasks. The first is the replacement of the front swivel balls and pins, bearings etc. The hubs are now stripped down but a solid caliper bolt on the drivers side meant it had to be drilled out leaving an elongated hole and part stripped thread in the housing. The other calpier bolt was ok. I thought about a helicoil repair but I've not done one before hence lack the experience. I'm also not keen on the idea given its brake related !!!! A replacement housing is therefore on the cards. I have ordered new swivel balls and got new pins and bearings etc. I'm struggling to find a drivers side new housing - the part ref is HRC2374. Does anyone know where I could get one. I'm based near Cardiff. Thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2013 Share Posted January 3, 2013 HRC2374.that's not a LR part number, just a unmachined casting number. you need this one FTC3308 http://www.brit-car.co.uk/product.php?xProd=103267 left & right swivel housings item 1 in http://lrcat.com/#31/4/52607 Quote Link to comment Share on other sites More sharing options...
StevenK Posted January 3, 2013 Author Share Posted January 3, 2013 Thanks Ralph Much appreciated. Would Bearmach do such a part as they are local to me ?? I note your recovery work. I do a bit of gravel rallying when funds allow, most of it in Wales. I expect you've been to God's Country when doing some of your recovery work ??. Probably seen you about over the last 30 years. Hoping to do the Wyedean if I can get a permit and the 90 stops costing me the hard earned. Cheers Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2013 Share Posted January 3, 2013 Bearmach should be able to sort one for you, Done a few events in Wales, red dragon.swansea bay, cearwent, possibly assisted you at some point in the past. Quote Link to comment Share on other sites More sharing options...
