300 tdi bearing squeal
Frax
Hi all I have a squeal coming from the idle pulley on my timing belt cover, it was a bugger to find but today I removed the belt and started her up and no noise. I fitted a new water pump and alternator last year so was hopping that they were still OK.
Anyway with the belt removed the squeal stopped the bearing does not feel that bad but does have very slight play and sound dry.
Has anyone had the replace the bearings for one of these, I am not looking forward to this job as the cover will have to be removed for a start.
Any advice welcome.
Sadly not that one, although I did change that pulley for a 2nd hand one as I did think it was that to start with but sadly no.
Its the bearing for the pulley that the fan connects to. I have had a hunt and it does not look good so far as most people say that the whole cover has to be replaced.
Do you mean the bearing in the front cover ?
If so have a look at REEDEX.net. Colin was looking into this a few years ago.
Otherwise it's a new front cover, there was a lot of covers on flee bay the other week.
