Frax Posted January 27, 2013 Share Posted January 27, 2013 Hi all I have a squeal coming from the idle pulley on my timing belt cover, it was a bugger to find but today I removed the belt and started her up and no noise. I fitted a new water pump and alternator last year so was hopping that they were still OK. Anyway with the belt removed the squeal stopped the bearing does not feel that bad but does have very slight play and sound dry. Has anyone had the replace the bearings for one of these, I am not looking forward to this job as the cover will have to be removed for a start. Any advice welcome. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 27, 2013 Share Posted January 27, 2013 No I haven't changed one. There should be plenty of posts on how to on the forums. IIRC a motorbike shop should have the bearings in stock. Quote Link to comment Share on other sites More sharing options...
western Posted January 27, 2013 Share Posted January 27, 2013 if it's the same idler as this one, then you can replace the bearing in your existing idler http://forums.lr4x4.com/index.php?showtopic=3904 Quote Link to comment Share on other sites More sharing options...
Frax Posted January 27, 2013 Author Share Posted January 27, 2013 Sadly not that one, although I did change that pulley for a 2nd hand one as I did think it was that to start with but sadly no. Its the bearing for the pulley that the fan connects to. I have had a hunt and it does not look good so far as most people say that the whole cover has to be replaced. Quote Link to comment Share on other sites More sharing options...
western Posted January 27, 2013 Share Posted January 27, 2013 photo's don;''t seem to work, thread was begun in 2008, but it might help http://forums.lr4x4.com/index.php?showtopic=32248&hl=%2Bfan+%2Bbearing+%2B300tdi#entry663362 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 27, 2013 Share Posted January 27, 2013 Sadly not that one, although I did change that pulley for a 2nd hand one as I did think it was that to start with but sadly no.Its the bearing for the pulley that the fan connects to. I have had a hunt and it does not look good so far as most people say that the whole cover has to be replaced. Do you mean the bearing in the front cover ? If so have a look at REEDEX.net. Colin was looking into this a few years ago. Otherwise it's a new front cover, there was a lot of covers on flee bay the other week. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 27, 2013 Author Share Posted January 27, 2013 Thanks for that - will have a read and see what is required. Yes it is the bearing in the front cover, I have ordered a bearing for the tensioner and will fit that to my spare as well. Quote Link to comment Share on other sites More sharing options...
