western Posted September 17, 2006 Share Posted September 17, 2006 This is how I installed EPC to my laptop, which is running XP Pro Start the Program Compatibility Wizard [PCW] Click 'next' Select 'I want to locate the program manually’ Click 'next' Click ‘Browse’ Under CD drive, find ‘EPC’ folder, double click it, Select ‘SETUP’ then click ‘open’ This will enter it into the long box, Click ‘next’ Select run under Win95 Click 'next' Installation should now begin. Follow on screen instructions When asked select 'EPC server version includes client version' when asked for dealership type enter 'Land Rover' reboot PC, ignore any error message, [just click the OK box to make it go away] Re-start PCW and do a similar operation for the 'AKM100’ select ‘SETUP’ this will enter it into the long box, click ‘next’ Select to run under Win95 this should now start it's installation, follow the on screen instructions if you want to install the 2002 update CD as well use the PCW to install this, using the method above find ‘SETUP’ and choose Win95 Follow on screen instructions If you have Norton 2003 or 2004 Internet security installed Open ‘Personal Firewall’ then ‘Configure’ Tick ‘automatic program control’ box Click ‘add’ Select your CD drive ‘look in’ at top of page Double click ‘Unicat’ folder Double click ‘Epc’ folder Double click ‘Software’folder Double click ‘Bin’ folder Double click ‘Server’ folder Select ‘Unifatfat’ Click ‘Open’ When prompted by Norton select ‘Permit All’ then click ‘OK’ then close Norton Repeat above sequence But double click the ‘Client’ folder & select ‘Unicat’ then click ‘Open’ When prompted by Norton select ‘Permit All’ then click ‘OK’ & Close Norton at this point I rebooted my laptop. When all is ready double click the EPC grey folder on your desktop and you should [as I can] use it as if it was on a Win95 or 98 PC, I hope it works for you Sequence Revised 16 March 2006 at 1915. Link to comment Share on other sites More sharing options...
