Aragorn Posted April 3, 2013 Author Share Posted April 3, 2013 Ok folks some slightly related questions, i started drilling and tapping out the holes tonight and i'm wondering about two holes quite high up on the bulkhead, i'm not sure if they are supposed to be tapped or plain holes or what... I've circled them in red: https://www.dropbox.com/s/solb3e7pgrm9dlz/IMG_20130328_141053_annotated.jpg Also, the green studs, what are they for? Any tips or pointers on drilling the zinc out of the flap hinges? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 3, 2013 Share Posted April 3, 2013 The ones high up on the bulkhead are for the wing tabs 3 studs would be for the ABS valve block I would think ? Zinc out of the vent holes was a right git to get out Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 3, 2013 Author Share Posted April 3, 2013 Les: Are the wing tabs M6 bolts like most of the other drillings, or something else? If the studs are for the valve block i can ignore them i guess, as i dont have ABS. edit: ah, looking over your thread, your bulkhead has two holes each side, which presumably takes some sort of rivnut or captive nut plate, mine only has one hole each side. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted April 5, 2013 Share Posted April 5, 2013 I hope you guys don't mind me asking, but roughly how much does it cost to get a bulkhead galvanised? (assuming it's fully prepped already) Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 5, 2013 Author Share Posted April 5, 2013 I paid £50 to have this galved at Pillar Wedge in Heywood. It was a further £75 to have the paint stripped off at a place called ribble technology in preston. Some people have them sandblasted, but i wasnt keen on that, because i wanted to ensure all the internal cavitys were fully galvanised, and you cant sandblast what you cant see! Ribble Technology have some chemical dipping process which strips off all the paint, which meant it was fully stripped inside and out. Quote Link to comment Share on other sites More sharing options...
