Mariner Posted March 30, 2013 Share Posted March 30, 2013 Hi, Series 3 with parabolics front and rear. Generally runs well and ride is as expected. However during last MOT it was pointed out that the fold over on both front bushes touches the main chassis above the bolt mount. Can anyone give me any pointer to the cause- can it be worn bushes (my main thought) though it does not look like they wre out of position. Just like some input before I shell out for new high quality ones. The present ones are about 7 years old but the truck gets very little use and is maintained in a garage all year round. No photo at present but will upload if this could help. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted March 31, 2013 Share Posted March 31, 2013 Depends on the manufacture of the springs I believe Britpart had a bad batch of springs with that problem ie the wrap around section was too high. If bushes have failed they can be moved in the mounting. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 31, 2013 Share Posted March 31, 2013 Bearmach had the same issue some years back, the cure was heat the outer eye with the oxy torch and close the eye a bit so it then cleared. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 2, 2013 Share Posted April 2, 2013 The LRM magazine, Britpart sponsored and conducted build showed the same problem with their new springs. Not a great advert for their products. They did the same thing once the fault was spotted. Shame they didn't repaint the spring eds before refitting - the scorched and blistered paint didn't look that neat against a galvanised chassis and newly painted panels! Quote Link to comment Share on other sites More sharing options...
