Front passenger window problem 300tdi
4x4disco
I wound the window down; it will not wind back up, stripped off the door panel and found that there is only around 6 volts showing at the door motor block connection.
The Rac Man ‘jumped’ the window closed using a power pack so we could drive home, he could find no obvious reason for the lack of power.
It’s not the switch as I swapped them around.
it’s not the 30amp fuse as its been swapped around.
Anybody have any ideas where to start looking for the problem, all other windows work ok.
Thanks
Sean
Car is a 1996 Discovery 300tdi auto jap import
I'm not an expert but my thinking would be to check earth points as high resistance here can cause voltage drops.
I would check behind glove box and determin if you have the earlier vehicle relays (to check in and out volts) or a later ecu and read these.....
Found these useful:
linky1
linky2
HTH....Hopefully someone more knowledgable will pop up soon :)
