Should I use silicon sealant??
richardm6994
Hello If you want to use a sealer on a gaskit there are only two things i would use
1; greace if you want to remove the cover and reuse the gaskit.
2; Wellseal aply a small amount to both sides of the gaskit and joint face wait untill it has dried a little and then asemble.
I have used welseal in my job as a motorcycle enginer, you must make sure that the serfaces are clean! A lot of people have leaks because they done clean of old gaskits and sealer.
I hope this helps
