Josh NZ Posted June 5, 2013 Share Posted June 5, 2013 Hey all, This may be a really silly question, but can you interchange 2dr and 5dr roof parts? The reason I ask is that I'm searching for a roof for my Stage 1 2dr, and I got offered a Safari roof with rear door off a CSW for a pretty good price. Problem is, I need longer side panels to fit a 2 door.. Assuming I can find some side panels off a 2 door can I swap them for the 5dr side panels to create a 2dr safari roof? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 5, 2013 Share Posted June 5, 2013 The roofs are fundamentally the same. The only difference is that a Staion Wagon roof will have Alpine Lights (the ovalised windows) and possibly have a Safari panel (second outer skin for shading and heat control) and four vents (like mini sunroofs) in the centre section. They are directly interchangeable, being a bolt-on, bolt-off affair with the same gutter and basic aluminium panels as the plain roof on a utility model. The side sections for a utility 109 would have been solid panelled from the factory, but many have been fitted with windows. If you can't find a good pair of 109 panels, then worry not - 110 panels bolt straight in too and are dimensionally identical. They differ slightly on the door seal flanges, but Defender door seals are a nice, simple upgrade anyway. Quote Link to comment Share on other sites More sharing options...
