Sabre Posted June 30, 2013 Share Posted June 30, 2013 I need to replace the engine mounting on the turbo's side of my Discovery 300 TDi Is it an easy job ? Any pointers ? Quote Link to comment Share on other sites More sharing options...
Boydie Posted July 1, 2013 Share Posted July 1, 2013 Very easy, use a good hydraulic jack, loosen the engine mounting by removing the nuts, raise and support the engine and replace the mounting, lower and replace the nuts. If you need to replace one do them both. Quote Link to comment Share on other sites More sharing options...
