greenstream Posted July 5, 2013 Share Posted July 5, 2013 Hi I've recently biought a 4.6 without the inlet and plenum. I do have the parts from a 3.9 - are these interchangeable without detuning the 4.6 ? Or should I simply opt for a 4.6 inlet and plenum ? Thanks Morten Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 5, 2013 Share Posted July 5, 2013 Yes 3.5 3.9 4.0 and 4.6 (non Bannana type) all interchange. Trumpets are the same hight etc The differences between the various plenums are 3.5 4.0 4.6 - no Stepper on the rear and differnet pipe in / out arrangements 4.0 and 4.6 very similar TPS different on 3.5+3.9 vs 4.0 4.6 3.9 has steeper motor on rear can be plugged port air entry same on them all, 3.9 3.5 are reputedly better cast to rev, 4.0/4.6 cast more for grunt 3.5 3.9 vs 4.0 4.6 have different length bolt to bolt to trumpet - same thread shortwer on 4.0 / 4.6 HTHNige Quote Link to comment Share on other sites More sharing options...
greenstream Posted July 5, 2013 Author Share Posted July 5, 2013 Yes3.5 3.9 4.0 and 4.6 (non Bannana type) all interchange. Trumpets are the same hight etc The differences between the various plenums are 3.5 4.0 4.6 - no Stepper on the rear and differnet pipe in / out arrangements 4.0 and 4.6 very similar TPS different on 3.5+3.9 vs 4.0 4.6 Please explain TPS 3.9 has steeper motor on rear can be plugged port air entry same on them all, 3.9 3.5 are reputedly better cast to rev, 4.0/4.6 cast more for grunt Are we still talking about the plenum here ? Edit self, you are talking about the "tubepart" of the inlet, from the trumpets and down towards the inlet valves ? 3.5 3.9 vs 4.0 4.6 have different length bolt to bolt to trumpet - same thread shortwer on 4.0 / 4.6 So I have to beware of which bolts I Use ? HTH Nige Thanks for your reply, could you please look at my comments. Could I use the 3.9 injectors as well ? I take it from your reply, that by using the 3.9 parts then I will not detune the engine ? Thanks Morten Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 5, 2013 Share Posted July 5, 2013 TPS = Throttle Position Sensor 3.5 3.9 vs 4.0 4.6 are different and loom / plugs are not the same the 3.5 3.9 are a smother / more flowed Plenum which can assist high flow of air at higher rpms vs the coffin shaped 4.0 / 4.6s which are more for bottom end grunt 3.9 4.0 4.2 and 4.6 hotwire all share a common injector, so same on all you must not only use the plenum of choice but use the bolts that come with it !Hope this clears it up Nige Quote Link to comment Share on other sites More sharing options...
greenstream Posted July 7, 2013 Author Share Posted July 7, 2013 Yup - thats more like my "lingo" Thanks Nige. Quote Link to comment Share on other sites More sharing options...
