doctor Posted August 10, 2013 Share Posted August 10, 2013 Hi all,I want to up rate the brakes allround my 97 disco auto.At the moment it has solid discs all-round with abs,single brake line into the rotors on each wheel.I read here that you can put the bigger defender rotors on the front but what about the rear.Also what discs- drilled ex, can be used in this set up and are the rotor bolts a different [length, size].At the moment I have orderd a new abs master cylinder and servo.Part numbers for the rotors and discs would help with ordering. Love the forum and thanks for the help .I am slowly getting the disco ready for a cape york trip. Quote Link to comment Share on other sites More sharing options...
4x4disco Posted August 12, 2013 Share Posted August 12, 2013 I upgraded mine to britpart drilled discs with ebg yellow pads, made a world of difference. Direct replacement for the std items. Make sure you bed the pads in or they are scrap. Quote Link to comment Share on other sites More sharing options...
