Sunroof catching when opening
Steve Warman
I have a problem with the rear sunroof on my 300tdi es
When the rear sunroof is opening it doesn't seem to clear the catches at the back and doesn't seem to angle up as much as the front.
I wondered if anyone has had a similar problem or can give me some tips on what I can check to make sure everything's as it should be?
I did read a thread that said about lining up the dots on the gears but it didn't detail where to check
Thanks
Steve
A photo would help showing the catch u mean, there are a few nylon/hard plastic sliders and rollers that can break up if one does then one side will operate lopsided.
The dot is on the motor (yellow paint) and the main driving wheel and is factory set so unless the motor has been touched and now not inline, then u will have an issue with the sliding operation.
