need4speed Posted December 23, 2013 Share Posted December 23, 2013 As per Niges recommendations i want to use the 300TDI air cleaner assembly on my 4.6. Has anyone used this? If so, is the air cleaner body mounted to the V8 using the standard 300TDI air cleaner mounting brackets or is fabricating some brackets necessary? Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted December 23, 2013 Share Posted December 23, 2013 A mate of mine did this, his was fixed to the bulkhead at the rear of the engine and used a series of silicone bends and ally joiners to connect it to the plenum. He used the quick release type clamps as fitted to the 300Tdi filter box to mount, it looked neat but if using a 4.6 I'd use a high flow filter like a K&N or itg as some 300Tdi types are restrictive. Quote Link to comment Share on other sites More sharing options...
