Frogland Posted December 27, 2013 Share Posted December 27, 2013 I'm looking at purchasing a 300tdi 1996 manual disco,the owner says it needs a new transfer box because the lever is stuck in high range he also says that the odometer has ceased to function. Could there be a link between the two problems ? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 27, 2013 Share Posted December 27, 2013 The transfer box will be a seized linkage, very common symptom on a vehicle that has never been used in low range. The odometer could be one of a few things, but if there is no speedo reading and the odometer doesn't work either, I'd start with the sender in the transfer box. If it isn't that, then none of it is rocket science to fix, it is a pretty simple system. Use it to beat the price down, and (probably) fix it for next to nothing Quote Link to comment Share on other sites More sharing options...
Frogland Posted December 27, 2013 Author Share Posted December 27, 2013 Yeah that's what i was thinking,I just don't want to accidently fix whilst i'm there.I've done that before ! Quote Link to comment Share on other sites More sharing options...
Frogland Posted December 27, 2013 Author Share Posted December 27, 2013 Is there a way to tell if there's a problem with the transfer box without actually using it ? Quote Link to comment Share on other sites More sharing options...
