callum22 Posted December 28, 2013 Share Posted December 28, 2013 I have a Series 2a with a 200tdi fitted, i have connected a R380 stubby gear box and a LT230 trans box. Its a series 2a designer chases which was previously fitted with a 200tdi and a series 2a gear box + trans box in place with no modification. The axies are from a D90 with coils. I was wondering does anyone know what gearbox mounts i need to use for the new R380 + Lt230? Any help will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Spongie Posted December 28, 2013 Share Posted December 28, 2013 Use the removable crossmember from a cooler with it Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 29, 2013 Share Posted December 29, 2013 Use the lt230 mounts. You'll have to chop the series mourns off the chassis, then drill the chassis for the lt230 mounts to suit and weld tubes in to stop the box sections from being crushed. It's not a bolt in job and will require some fabrication. Jo Quote Link to comment Share on other sites More sharing options...
