sighnbox Posted January 9, 2014 Share Posted January 9, 2014 Hi does any one know the weight of a 1990 110 station wagon/Defender please (about ) Basicly Are 2 tonne axe stands ...jack Ok please Thanks there Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 9, 2014 Share Posted January 9, 2014 2 tonne should be fine. Bigger is always better though with axle stands more for stability than weight load. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted January 9, 2014 Share Posted January 9, 2014 2 tonnes for one axle is easily enough, and even if you use two sets to support both axles, theoretically you could support 4tonnes, LOADS!!!! Quote Link to comment Share on other sites More sharing options...
toenden Posted January 9, 2014 Share Posted January 9, 2014 Hi, To answer your initial question: My 110" stw from 1989 with a retrofitted 300tdi and r380 is weighing in at approx 2100kg with a full tank. Regards mads Quote Link to comment Share on other sites More sharing options...
sighnbox Posted January 9, 2014 Author Share Posted January 9, 2014 Thanks guys Quote Link to comment Share on other sites More sharing options...
