Matt BADLRC Posted January 25, 2014 Share Posted January 25, 2014 My 98 V8 discovery won't idle properly. Sometime it idles OK when cold sometimes not.Its worse when its hot, it only idles at about 500 but seems a bit lumpy. Ignition leads, plugs rotar,cap, crankcase breather filter etc all recently new drives and revs OK just an idle problem. Cleaning the idle valve fixed it for a short while, tried cleaning again yesterday made no difference. Anybody had any issues similar to this and what fixed it. Going to clean the plenum out and tweak base idle next I think. Quote Link to comment Share on other sites More sharing options...
IanS Posted January 25, 2014 Share Posted January 25, 2014 I changed the base idle on mine (despite lots of warnings not to) as I had similar symptoms and it was fine for several years. Quote Link to comment Share on other sites More sharing options...
Matt BADLRC Posted January 25, 2014 Author Share Posted January 25, 2014 I cant find the base idle adjuster for the allen key to adjust the idle. is it on the 3.9? Quote Link to comment Share on other sites More sharing options...
bluespanner Posted January 25, 2014 Share Posted January 25, 2014 Matt you have a stepper motor, or idle air control valve. Try cleaning it out Quote Link to comment Share on other sites More sharing options...
bluespanner Posted January 25, 2014 Share Posted January 25, 2014 Ignore that - I skimmed your post. Maybe time for a new one? Quote Link to comment Share on other sites More sharing options...
IanS Posted January 26, 2014 Share Posted January 26, 2014 Mine was a 3.5i. The adjuster was under an alloy cap near where the flexible pipe from the air cleaner goes into the plenum but it was a long time ago when I did it. I had to pierce the cap & lever it out. Quote Link to comment Share on other sites More sharing options...
