sargejnr Posted January 25, 2014 Share Posted January 25, 2014 my sister in law has a disco 2 and has trouble starting it, she turns the key and all lights come on dash then turn bit further to start and just a single click and nothing, any ideas would be very much appreciated Quote Link to comment Share on other sites More sharing options...
bear Posted January 25, 2014 Share Posted January 25, 2014 Hi, Assuming you have a good & charged battery it sounds like a starter motor problem. Make sure the elec terminals are clean & attached and do a search for replacing the contacts in the starter. These can be done apparently without removing the starter. HTH, Griff Quote Link to comment Share on other sites More sharing options...
Disco DJ Posted January 25, 2014 Share Posted January 25, 2014 Good news!! This is a well documented common problem and a cheap fix! See; http://www.repairkitsuk.com/1.html Bad news- it's a fiddly job! Done it myself, DIY grade repair but does take time! Quote Link to comment Share on other sites More sharing options...
