FITZYNKAZ Posted February 12, 2014 Share Posted February 12, 2014 hi im new to discos bought a 300tdi es model for 400 got it road legal now looking to take off road bought this http://www.ebay.co.uk/itm/331121638859?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 do i need anything else to fit it ?? cheers alex Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted February 13, 2014 Share Posted February 13, 2014 That should be all you need for a basic lift, but if you are doing a lot of off road I would fit extended brake lines and remove the antiroll bars. You may have issues with the castor on your front axle which may cause bump steer and wooly steering on road but it doesn't effect everyone with a lift. The doughnut on the rear prop may wear out quicker (if it's not already worn out) so bear that in mind too. Quote Link to comment Share on other sites More sharing options...
FITZYNKAZ Posted February 13, 2014 Author Share Posted February 13, 2014 i have the extended lines the kit came wit 5 goodridge ones unused sorry to sound dumb buts whats the castor on front and donut on rear as a mates scrapping a disco so will grab em Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 13, 2014 Share Posted February 13, 2014 Okay... +4" shocks add a whole bunch of requirements. The shocks will bottom out and the springs will unseat. If you want to keep them... - You will need to limit compression travel with longer bump stops or change the shock mounts. - You will need to add spring retainers or dislocation cones to prevent the springs from unseating (those are in the picture, but not the description) - You will need longer brake lines (those are in the picture, but not the description) - You will need higher angle propshafts to prevent binding on full extension. Quote Link to comment Share on other sites More sharing options...
FITZYNKAZ Posted February 14, 2014 Author Share Posted February 14, 2014 Okay... +4" shocks add a whole bunch of requirements. The shocks will bottom out and the springs will unseat. If you want to keep them... - You will need to limit compression travel with longer bump stops or change the shock mounts. - You will need to add spring retainers or dislocation cones to prevent the springs from unseating (those are in the picture, but not the description) - You will need longer brake lines (those are in the picture, but not the description) - You will need higher angle propshafts to prevent binding on full extension. i received the kit today i got all items in the picture if it helps all for 120 posted does that sound ok { made him offer after auction closed } Quote Link to comment Share on other sites More sharing options...
