Constant Clicking Flasher Unit ONLY when engine running
GarryG
Weird fault.
Heard a constant clicking/relay switching whilst engine running.
investigation to date,
All bulbs working
Only does it when engine running
Don't do it with ignition on, but not started
stops when indicating/ hazards on.
Replaced Flasher unit same problem.
Checked Stalk, operation, cleaned.also plugged in new spare, no difference.
Noted the unit clicking is an add on Trailer lighting unit. But as it's Bobtail no Trailer socket, no signs of chopped wiring.
The original (2 pin) flasher unit is still in situ (wired) but don't seem to work.
Where to start
Should the original 2 pin still operate, if so New one needed. quick fix
Those in the know will say Earthing, but where to start.
any offers of advice
