RMEHUNTER Posted May 2, 2014 Share Posted May 2, 2014 Can anybody tell me how about how many hours it takes to remove a TD5 head and also re-install one? It looks like I need to do mine and my mechanic is very fair in his prices and he will charge me actual hours but I need a ball park. Thank you. Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 2, 2014 Share Posted May 2, 2014 According to autodata: A2.0700 Cylinder head & gasket R & I : 3,50 Includes: A2.0200 Camshaft/valve cover & gasket R & I A3.2300 Camshaft drive belt/chain R & I A3.2500 Camshaft chain cover & gasket R & I A4.0400 Crankshaft pulley R & I A5.0110 Engine oil & filter Renew A6.0500 Alternator drive/serpentine belt R & I C1.0100 Air filter assembly R & I C1.0600 Intake manifold R & I D1.0100 Coolant/antifreeze D & R D1.0500 Cooling fan coupling R & I D1.0700 Cooling fan R & I D1.1300 Radiator cowling R & I E1.1310 Exhaust - front/downpipe(s) Disconnect Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 2, 2014 Share Posted May 2, 2014 Or A2.1700 Cylinder head - transfer components S & R : 6,90 Includes: A2.0200 Camshaft/valve cover & gasket R & I A2.2500 Rocker shaft assembly R & I A2.2900 Valves (all) including lapping R & I A3.0100 Camshaft R & I A3.2300 Camshaft drive belt/chain R & I A3.2500 Camshaft chain cover & gasket R & I A4.0400 Crankshaft pulley R & I A5.0110 Engine oil & filter Renew A6.0500 Alternator drive/serpentine belt R & I C1.0100 Air filter assembly R & I C1.0600 Intake manifold R & I D1.0100 Coolant/antifreeze D & R D1.0500 Cooling fan coupling R & I D1.0700 Cooling fan R & I D1.1300 Radiator cowling R & I E1.1310 Exhaust - front/downpipe(s) Disconnect Quote Link to comment Share on other sites More sharing options...
