muddy Posted June 15, 2014 Share Posted June 15, 2014 I need some new ones of these plugs seen as though i some idiot forgot to disconnect the gearbox loom when lifting the body off and have pulled the pins out. Does anybody recognise them/ have any or know where to get them? They are off a Td5 disco II auto. Also does the ribbon in this selector look right I think I forgot to disconnect that plug too....... Or if anyone has the gearbox loom part no. I can price that up if no connectors are available. The perils of burning the candle at both ends Thanks in advance, Will. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted June 15, 2014 Share Posted June 15, 2014 Unless you can source a 2nd-hand one at a good price, you won't want to buy a new gearbox harness - they're around £280 The first two (White) connectors are AMP Multilock 6-way & 10-way female. I have those connectors, with or without terminals. The connector on the selector is a 12-way AMP MQS connector (I have those too), it's difficult to see from the picture if it or its wiring are damaged. PM me Quote Link to comment Share on other sites More sharing options...
muddy Posted June 18, 2014 Author Share Posted June 18, 2014 This is the other broken connecter, this and the two white ones pass through the body onto the gearbox loom. Paul pm on its way.... Quote Link to comment Share on other sites More sharing options...
