rrr47 Posted September 25, 2014 Share Posted September 25, 2014 I have, (after 4 years without a heater), ordered a new heater matrix. Has any other members change the said part? I am hoping I don't have to remove all of the dash. Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted September 25, 2014 Share Posted September 25, 2014 The matrix is quite a small part of the heater assembly, whichyou do need to get completely out of the car to work on. However, it it's not necessary to remove all the dash, I know 'cos I've done it. Mine a 1990 Vogue SE 3.9 EFi Automatic. I removed the centre console and lower dash to get access to the heater and ducting. One thing I did find which made it possible to do without the whole dash out was this. The heater assembly was fouling on the transfer lever, it is possible to take the transfer lever off its pivot (I think it's a circlip on memory) which allows the lever to move out of the way, and then the heater assembly wriggled out. I'm not going to pretend to you it was easy, it wasn't! Lots of nimble fingers and wedging yourself upside down in the footwells required. Quote Link to comment Share on other sites More sharing options...
rrr47 Posted September 25, 2014 Author Share Posted September 25, 2014 Thanks for the reply and advice, I will try your method. I am not looking forward to do the job as I have done this a few times on various cars and, with exception of two, it was whole dash out job. On a Cortina and Manta, (the other two), the same job is a few crosshead screws and two Jubilee clips under the bonnet, with the heater fans just as easy. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 25, 2014 Share Posted September 25, 2014 It is virtually a dash-out job, as above I wriggled mine out a bit, and managed to leave the top of the dash, including the main clocks in place, which saved mucking around with all that gubbins, slid it out into the passenger footwell I think, was a few years ago now. Quote Link to comment Share on other sites More sharing options...
