bigstevemex Posted September 28, 2014 Share Posted September 28, 2014 I have recently bought a disco 2 2002 td5 and it's having some electrical problems The front and rear wipers and rear parking sensors don't work nor does the front screenwash And the heated screens. I am presuming that there is a body control module fault Can it be repaired or does it have to be replaced? My wife said the car beeped a couple of times the other day but no warning lights Any advice gratefully received Quote Link to comment Share on other sites More sharing options...
steve_a Posted September 28, 2014 Share Posted September 28, 2014 If the car has SLS then the beeping was probably indicating it was pumping up during start up. As a newbie to the D2a with SLS I was also confused by the occasional beeping as I started up, thinking it was ABS or similar (the same beep happens when the 3 amigos kicks in...). The rest is probably a fuse, have you checked the drivers footwell and engine bay? The BCU is probably not the first place to look since it also controls headlights, indicators, windows and lots of stuff. Quote Link to comment Share on other sites More sharing options...
