cookie64 Posted October 14, 2014 Share Posted October 14, 2014 Hi guys I'm running an event to raise money for mountain rescue and my local independent parts dealer has decided to send me a 110 CSW to use for the duration of the 4 day event I havnt any access to the vehicle yet but need to get some signs made up to go in the rear windows I.e the ones on the side of the boot space Could anyone help me with some dimensions of the glass please do I know how big to make the signs so they are visable from the outside Thanks Tom Quote Link to comment Share on other sites More sharing options...
Diff Posted October 14, 2014 Share Posted October 14, 2014 Hi Tom, I have a 1985 110 CSW and I have just measured the total visible glass area each side to be 1030mm x 400mm. Note that the windows are made of two overlapping sliding bits of glass so you won't have a single flat surface of the entire dimension as above. If you are thinking of a single large 'sticker', you may need to take this into account. Don't forget the corners are radiused too. Hope this helps, Regards, Diff. Quote Link to comment Share on other sites More sharing options...
