oneandtwo Posted November 11, 2014 Share Posted November 11, 2014 Can anyone advise what unions I need to connect the fuel sender / pickup below? It is a genuine Land Rover pickup unit for a ROW 300tdi with a plastic rear tank. I assumed that the original unions and olives off the older metal tank pickup would fit but the diameter is different, the plastic tank pipes are 7.8mm OD wheras the old type pickups are 8.2mm. I don't really want to resort to rubber pipes and jubilee clips, I'd rather stick to the nylon rigid hose, particularly as I've fitted them to the chassis already and shaped them all correctly, but neither do I want to buy the correct genuine parts ROW 300tdi fuel line at £200 plus rear mounted sedimenter if I can help it. Thanks. Quote Link to comment Share on other sites More sharing options...
