vinny Posted November 6, 2006 Share Posted November 6, 2006 Hi Folks Im thinking of converting my 90 truckcap into a Hi Cap 90. Ive sourced a tub and bulkhead from a 110 and will chop it down to suit. I have the LRe mag that covered this conversion already. The fella didnt reattach the front of the Hi-Cap tub, he used Al treadplate to cover it up.. Can anybody explain why? Unless the front of the tub can be reattached to give a factory standard finish I propably wont bother with the conversion. Cheers Vinny Quote Link to comment Share on other sites More sharing options...
Litch Posted November 6, 2006 Share Posted November 6, 2006 From what I recall about the article he just used chequer-plate because he 'likes the look of it'. That's fine as it is his vehicle but I thought it completely spoilt what was otherwise a nice conversion and made it look home-brewed whereas with some flat alloy sheet it would have looked far more professional. Even if you need the strength that 2-3mm chequer-plate can give you can do the same thing with flat plate of the same thickness. As I said, personal preference as I hate chequer-plate. Quote Link to comment Share on other sites More sharing options...
vinny Posted November 7, 2006 Author Share Posted November 7, 2006 Im not a fan of chequer plate either, but was trying to figure out why he didnt reuse the front of the hi-cap tub? Would it foul the wheel arches or something? Would anybody have the dimensions or specs of a 110 Hi-cap tub? Quote Link to comment Share on other sites More sharing options...
vinny Posted November 10, 2006 Author Share Posted November 10, 2006 Ok next question then!! I removed the standard 90/110 diesel filler from the side of the tub and fitted the series type just behind the drivers door. If I use the Hi-cap truck cab bulkhead can I still fit the series filler? Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 10, 2006 Share Posted November 10, 2006 Ok next question then!!I removed the standard 90/110 diesel filler from the side of the tub and fitted the series type just behind the drivers door. If I use the Hi-cap truck cab bulkhead can I still fit the series filler? If you can physically fit it, no problem. The hi cap bulkhead has the same profile as the tub side although its very short. Quote Link to comment Share on other sites More sharing options...
