lynall Posted November 11, 2006 Share Posted November 11, 2006 Just reading the post in the tech archive and there was a mention of an Ian who supplied the gauges any idea where to get hold of Ian? Has anyone fitted one to a TD5? Just posted this on disco forum and was recomended to try on here. Would the old egr blank plate be okay for tc mounting or as it is really only in line with no1 cylinder not give a true reading? Thanks Lynall Quote Link to comment Share on other sites More sharing options...
mattD110td5x Posted November 11, 2006 Share Posted November 11, 2006 Just reading the post in the tech archive and there was a mention of an Ian who supplied the gauges any idea where to get hold of Ian?Has anyone fitted one to a TD5? Would the old egr blank plate be okay for tc mounting or as it is really only in line with no1 cylinder not give a true reading? Thanks Lynall Hi Lynall Ian is at thermoguard in Australia: ThermoMan@bigpond.com he will post anywhere - even the Falklands. http://www.thermoguard.com.au/ He is most helpful.... in an email Ian sent me a while back; --------------------------------------------------------------- ...... Sorry, but the Tdi blanking plate won't fit your Td5 EGR 'hole'. In fact, my standard thermocouple would be struggling to reach into the gas flow from the Td5 EGR flange - it's quite deep. But, the Td5 is probably the easiest recent engine to fit an EGT sensor into. The collector, which feeds into the turbo, is very accessible and it's a fairly straight-forward exercise to drill and tap into the manifold just before the turbo flange. And it's quite easy to temporarily disconnect the turbo from the manifold while the drilling and tapping is done. I'll attach a photo of a Td5 installation to illustrate the recommended thermocouple location. Please be in touch if you'd like more details. Ian P. ----------------------------- Quote Link to comment Share on other sites More sharing options...
